As I can see your U47 is pretty old (i presume it's from the end of 1940's). Those days resistors were double or triple sized compared to present production. I can't see any other reason than dimension to go with lower W rating :/ Also, don't be lazy and check all the values of resistors. If the are within 5% then OK but it's possible that thy changed the values over the time.sr1200 said:You're the best man, i can't thank you enough! Out of curiosity, why did they not just use .25 watt resistors all around? Why the .1 watt?
That is the rectifier bridge.sr1200 said:I just found 3 schematics, that have no identification as being neumann, but one has 4 caps, one has 5 and one has 6. lol
On none of them do i see this guy... (attached pic) Any thoughts?
