rock soderstrom
Tour de France
WrongAh ok I get it now
6.28 x 200000000 x 0.000072 = 90432
1/ 90432 = 0.00001106
Its 0.000000000072F
fc=1/(6.28x200000000x0.000000000072)
Story of my life!!!
Wrong
Its 0.000000000072F
You are not alone, I did it wrong at first too....Major brainfart there, so very sorry Picofarads are 10^(-12), of course...
Yes, in my humble opinion, reducing the coupling capacitor from the anode to the output transformer would be a good place to limit the LF range.Any opinions on that?
Folks correct me if I'm wrong, but reducing the Rg is only possible within limits, as otherwise the very weak signal of the capsule is loaded down too much. The capsule prefers to play into a very high impedance.a) lower the value of the capsule resistor even further; say to 25M to get rid of the LF in the first place (e.g. by switching another resistor in parallel to my 100M one to reduce the overall resistance on demand)
First, your maths is right from my point of view.But then I was stuck with that very rolloff, there was no going back - no switchable solution. Did I get that right?
Keep us informed about your experiences with the changes.I’ve just realised I have used a different transformer in my first version!!
That’s why the output level is so different, I’ll also change the 200m resistor for 100m by putting another 200m in parallel and the other 200M resistor I can change to a 60M as I have a 50M and a 10M, I’ll also change the anode 1uf cap for a 0.5uf
That depends on your power supply unit. It may be that after switching on, when the heater of the tube is not yet warm, the 160V is exceeded, because the tube does not yet draw any current. Which PSU are you using? Schematic?Would you say these do the trick (160V instead of the 250V ones I currently use)? Or do you have any other recommendations?
Yes I will, my version 1 sounds great and it’s got a U87 9.5:1 transformer in it, it uses 1G resistors and 1uf caps but I’m happy with how it sounds so I’m kind of loathed to change it.Keep us informed about your experiences with the changes.
If you like it, I would leave it as it is, for sure.Yes I will, my version 1 sounds great and it’s got a U87 9.5:1 transformer in it, it uses 1G resistors and 1uf caps but I’m happy with how it sounds so I’m kind of loathed to change it.
So sounds so good on the drums, acoustic guitar and vocals.
Ah right well makes sense, didn’t think it was making any difference!!
I have four EF80 and they all are quite microphonic, I chose this one as it was the least.
Will change for the EF800 when it arrives.
