Some very interesting discussion and reading in this thread since I last checked in!... It's an interesting concept / question: is it different to modulate the capsule vs. the signal-at-the-amp (or anywhere after).
The way I see it simplified is without thinking about a filter at all... just a raw feedback of the signal... e.g.
If you had a raw 1kHz test tone being recieved by a mic capsule (as in, out of a speaker, into the mic capsule), and you bypass the filter and:
a) feedback a small portion of the recieved signal to the amp input's signal (but inverse phase) then you're effectively reducing the level of the signal.
b) feedback a small portion of the recieved signal to the capsule polarisation to modulate it against the incoming signal, then, for me, that's the question: "is it the same outcome as a) above"?
a) is solid.
b)... well it's hard to grapple (to me, with limited knowledge but keen interest). My mind starts to play tricks on me, as I wonder how this feedback would work... this system would feedback the recieved voltage, which instantly lowers the signal level recieved at the diaphram by reducing the polarisation voltage, but that lowered level is the levels that's then actually recieved... which is fed back to lower the sensitivity which lowers the signal, and on and on.... I don't understand how this would be stable. But I don't understand a lot of things lol... and it has to be stable, because even with the ACTUAL filter used, this is what's going on (right?)... I imagine feedback to the capsule has a sort of logarhythmic reaction, where the effect of feedback lowering the level of the signal diminishes over and over until it's not "really" diminishing anymore and is effectively "stable", which is all instantaneous and what we end up hearing (as opposed to the signal instantly turning itself off due to constantly reducing it's own signal in e.g. a linear fashion).
So - my understanding above is possibly roughly correct, or just flat out wrong
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
... Eitherway, the question for me remains: "Is the result of this feedback in option b) the same outcome as option a) above"?
For feedback to the capsule to be identical to feedback at any point after that, it would entirely depend on the capsule having a linear reponse to voltage changes in the same way that it does with option a) above... a consistent sensitivity change for varying polarisation voltages (let's say "in normal operating conditions"). That's either how it is, or it's not... as a result, I see two options for what's actually happening:
- having the polarisation voltage modulated by the recieved signal slightly pushes and pulls the diaphram based on +/- incoming signals in a manner that restricts it's movement resulting in a change in signal that is the same amount as e.g. lowering the signal at any point after the capsule... i.e. a linear response.
- OR it is not a linear response, and the signal becomes distorted to some degree... i.e. it is NOT identical to doing this after the capsule due to non-linear ways polarisation voltages effect the recieved signal.
Man... but it kind of has to be Option 1... How else could a microphone with feedback networks recieve any filtered signal accurately with low distortion if it wasn't...
If it's Option 1, then the key benefits I see would be in diaphram protection / longievity... it physically restricts signals at the diaphram... sure not a huge amount physically, but certainly an audible / electronically signficant amount... and if those signals are areas that might cause damage like big plosives and such, then that has a benifit right?... HF filtering...? well less critical from that perspective... but if you're already filtering to the polarisation voltage, why not keep at it!?
