At last we have some results!
This has been a learning curve for me as it's the first feed forward Comp I've made and it has taken some time to get to know it.
It's a bit like setting up Windows without the built-in defaults, everything is variable so where do you start?
The calibration instructions in the manual are not detailed enough and the modern components in my version are sufficiently different, that the curves are shifted down from the original by 5dB, but are otherwise the same as you can see below.
If the controls are not properly set, then it's easily possible to make the gain fall so much that the curves instead of remaining straight, go negative ??? This is what happens if you just follow the manual, so I had to set up the output levels first and make sure that they stayed flat for the correct length and just let the linear amp section be whatever it turned out to be, and that is what the chart shows.
Although it's tricky to set up, there are no other artefacts to worry about as it's rock solid stable. Sometimes (often) feedback compressors can exhibit oscillation if the layout isn't perfect, but of course there is no setting up to do as the feedback type are self regulating.
Test Conditions and other data:-
Signal generator 600 ohms output Z
Input Impedance 20k
Output impedance 80 ohms
Tested with 600 ohm load on the output.
Signal to noise ratio as accurate as I can measure was:-
Hiss -78dB/Hum -70dB relative to +6dB output
These are all unweighted figures, with open input.
Frequency response to follow soon.
best
