U87 (Revision A) in BM800 microphone donor body
Nice idea! And are there any considerations regarding stiffness? You're essentially creating a dampened resonant mass-spring combination. Does it make sense to aim for a certain resonant frequency? Or should one just take the softest available?
FWIW, I use those rubber fan vibration isolators to mount an electret capsule holder on in a end-addressed mic. I've yet to test it in real life use, though. Maybe they are too floppy, I don't know. Mechanics are not my "core competence".🙄
Jan
Hi @jp8
Nice idea!
That's not my idea! It has been shared a build on this thread with it. I actually thought this was a standard that's why I was asking.
For me I see as a attenuator of any sort of movement dampening to the capsule, which inherently will help I guess. About any mechanics on it, we are on the same boat...somebody might know better to answer than me, I'm just following directions :D
Im nearing final assembly of my 87 boards!
I got an alternative T-13 9.5 to 1 transformer and Im not sure how to terminate it to the board.
There are 2 pairs of windings, wrapped together yellow - black, and yellow - black.
Yellow wires show continuity on a VOM meter.
here is a picture of the docs that came with the transformer.
How would this connect to the U87 fet PCB A V1_7 ?
@mihi_fuchs ?
@mihi_fuchs ?
Hi @theom !
ASTDS T-13:
Black - primary
Yellow - secondary
Just plug it in, respecting:
Primary(black) - to
pin1 of j2 conn transformer (C8=1uF)
pin2 of j2 conn transformer (GND)
and
Secondary(yellow)- to Output:
pin3 of j2 conn transformer
pin4 of j2 conn transformer
If the microphone is not in phase with any other commercial microphone(condenser or dynamic),
reverse the primary wires,
or secondary wires,
or xlr2 with xlr3.
To be sure that the manufacturer did not mistake the color of the wires, measure the ohmic resistance with the DMM
Between the wires that measure more, (about 395...483 ohms), is the Primary.
The other two wires measure less (16.74... 20.46ohms) represent the Secondary.
    188.4 KB
Hi @theom !
ASTDS T-13:
Black - primary
Yellow - secondary
Primary(black) - to
and
or secondary wires,
or xlr2 with xlr3.
exactly. i would do the same. only thing to mention is that the data gives you in the top right corner which wire is black one/ yellos one. start with that configuration and check phase alignment to be sure the data was fine. maybe spares you a few trials.
BR
Michael
BR
Michael
Thanks folks.
I was wondering how to determine which loop is primary.
Now I know,
theo
