pucho812
1. Mic powers on
2. Mic passes signal for a second
3. Loud pop then mic is silent not passing signal.
Capsule?
Capsule?
Hmmmm. I have two single capsules.. I suppose for test purpose a u87 in cardioid only be OK.It could be the capsule yes.
Do you have a spare LDC capsule that replace the original one for testing purposes?
that I know but I do not have access to a second unit at the moment.If you have access to another one the head basket is removable so you can easily swap the capsule
One for each side?Swap the capsule with a couple of 47pf caps and check voltages?
yeah, might be best to make a dummy head with the 300k resistor in it too. Then you don't have to unsolder the capsule wires.One for each side?
I’m no mic expert either. But I do fix from time to time.yeah, might be best to make a dummy head with the 300k resistor in it too. Then you don't have to unsolder the capsule wires.
Wrap in tin foil to keep out interference.
(I'm no mic expert, just thinking out loud!)
