chopstickkk
New member
- Joined
- Jan 19, 2009
- Messages
- 3
i'm currently using a pair of tannoy monitors that have no volume control. i recently upgraded to a soundcard that has only line outputs so i'm looking to implement a realllly simple single potentiometer stereo volume control.
and also i figure it'll be the ideal entry point to the diy world (get me used to soldering, making measurements etc.)
i would like it to be balanced. i've been lurking here for a while, reading craig anderton's book and the radio shack books and am wondering...
do i need to unbalance the signal on input and run it through the pot and then rebalance on output? (apologies if that sounds really stupid!)
also i have the option of buying a...
'Dual / Stereo Potentiometer with a low noise conductive plastic track. 6mm shaft. PCB pins. Can be PCB or panel mounted.
10k linear 1.85
10k log 1.85
47k linear 1.85
47k log 1.85'
what resistance and curve type will be suitable for a monitor controller operating on line level?
thanks in advance and any other info that you guys could offer would be great.
john.
10k linear 1.85
10k log 1.85
47k linear 1.85
47k log 1.85'
john.
