abechap024
to bad they don't make those kind of switches for the fuses on audiophile power amps :
zebra50 said:Is it not possible to build a little box to text this, using a couple of XLR (or TRS) connectors, and a switch to connect pin 3 to ground?
Then you can listen, switch, listen, switch.... (You may need to correct for a drop in level.)
I agree 100% on this. Unfortunately, it is often seen as an inferior solution to fully balanced. For this reason, it has been confined to budget mixers. Only in very demanding conditions would fully balanced show any superiority to impedance-balanced. But on sales litt, fully balanced gets +26dBu output instead of +20 (out of +/-15V power rails), FWIW.Seeker said:didn't see anyone mention it in this thread yet but alot of my gear is impedance balanced. Its very effective and its hard to get much more sonically neutral, though I don't see it brought up too much....
