while i'm waiting for some trafos from out member, i would like to understand this preamp better and squeeze a little more gain out of it. Schematic of V72S is attached, original gain is 40dB, as i will use 1:10 input trafo this is 6dB less, so 34dB.
This is enough for most situations, but there are some cases where i need ~10dB more, it would be nice if i could change it with a pot or switch.
First i would like to know more about how feedback works here. There are two resistors and caps in // from V2 anode to V1 cathode. This looks like frequency compensated NFB to me. There is also 50k resistor between V1 and V2 cathode which also looks like NFB to me, but i'm really not sure which because of voltage dividers in V1 and V2 cathodes and also because it lacks capacitor i'm used to see.
Oliver from TAB wrote that this preamp has DC and AC NFB along with positive feedback. I'm looking and looking at this circuit for days and can't understand it. Normally there is anode to cathode NFB with resistor and cap (or anode to anode like in Gates SA70), so i guess it's AC NFB. But here it's very different, i'm already lost at V2 anode to V2 cathode feedback which looks like negative and as i said compansated. But what about this DC/AC thing and positive feedback? There is also this voltage divider to V1 anode and G2. I think i understand it but 8u cap looks very high compared to any other circuit i've seen or built. Is it anode decoupling and just powers this two nodes?
I know i'm asking many things, i would be very happy if someone tells me about feedbacks for the start.
Google showed this classic "V-72 gain mod" from Recording.org (Oliver said it will form a filter beside variable gain), and another from Drip which i wouldn't trust since i've seen what they done to this and some other preamps.
