Universal Audio SC-1 Hemisphere Mic Modeling Is a Behringer
Here you are! Should work in Space Designer. Let me know how you get on.
Phenomenal! I'm getting a B-1 as soon as I'm back from Thanksgiving travel. For now to test out the workflow and proof-of-concept I'm using a Rode NT1-A which I don't remember buying...
Over on the UAD forums I seem to have gotten confirmation that the Hemisphere software comes with the models for all of their source mics, not just the source mic that was registered. This seems to mean that a $100 SD-3 would unlock all of that modeling (including B-1 modeling) plus you get a free dynamic mic with it ;)
Makes me wonder what other UA mics may be simple rebrands of existing ones. From what I'm seeing UA doesn't list specs like diaphragm size, which makes narrowing things down trickier.
Will keep you posted on how the IR works, thanks again!
Following on that last thought, it seems like for folks who want to use UA/Townsend's modeling tech to get in the ballpark of a lot of classic mic sounds there are a few different options:
1. Sphere LX - $800: dual diaphragm, most advanced option. UA claims you need the DLX to get stereo processing but that doesn't make sense to me. Couldn't you just run it into two separate tracks, run two instances of the Sphere plug-in, and configure one plug-in for the front diaphragm and the other for the rear?
2. SD-3 plus a 797 Audio mics - $450: The SD-3 is the cheapest Hemisphere mic and unlocks access to the other sources as well. So far it's believed that three other mics are suitable replacements for UA mics: $180 MXL-603S pair ~= SP-1, $80 BC 500 ~= SD-1, $80 B-1 ~= SC-1. Netting out 5 total modeling mics of various specialization averaging $90/mic
3. DIY CY002 capsule build + Townsend 1.5.2 plug-in: ~$100 + ~8 hours of effort? Should be roughly comparable to Sphere LX results, vastly cheaper. And, as a bonus, geekier too!
Are there considerations I'm missing, or options I've overlooked?
Obviously, when factoring in used pricing all of the above looks significantly different.
This is my version of your option 3. I am deeply indebted to this forum’s grandees for the necessary pointers that helped me put it together and it’s not really original because of the work they’d already done. With @kingkorg and @Wordsushi deserving special mentions, as well as Jukes Rykebusch for the circuits.
So it’s dual OPA Alice, CMOS inverter at 80v on a 797 CY002 in an “Ali ‘47” housing. I have also used kingkorg’s / Wordsushi’s foam mod at the base of the capsule, around the pedestal too because there is perhaps a touch of resonance in this headbasket.
I own the OG Townsend L22 since a few years but I now no longer have to bring it between my studio and my home because I’ve got another option! It sounds almost identical.
Costs: Capsule at £40, body about £60. Circuits built for about £40 (can be done for less I expect). Misc connectors, wiring and adaptation for fitment brings it to about £150 plus my own labour.
Wow, that would be amazing! Much appreciated, and I think likely a very useful resource for anyone looking to use non-Townsend mics with the free Townsend plug-in, regardless of DAW.
Hello i have Townsend mic but i don't have the plugin .. of you have can you please send it to me.. thank you KW
I believe it’s referenced on the thread if you look carefully. It was a freely available plugin before the UA acquisition but I would still be careful about publicly sharing it directly in case of falling foul of licensing. However if you at the UAD forums link, it’s been posted by someone else.
The great thing is it’s the latest 1.5.2 version which was Apple Silicon compatible. Unfortunately no AAX for our Pro Tools friends due to Apple Silicon issues at that time.
