kilmister
Hello all!
During the years I've been reading this forum and learned to solder something together. I've also managed to build couple of tube mics and some power supply units for them. At the moment I'm in middle of typical Apex460 to C12 modification and needed psu once again.
As a diyer I like etch simple pcb but don't like to make new design everytime application changes. What I wanted was one simple pcb design that I can use for all different kinds of mics just by swapping component values and jumpering some out depending on application. Also I wanted to use components which are available from local milk&bread store.
So here is what I finally managed to put together. It's a very simple design with following options:
-B+ is smoothed by CRCRCRC network and there is place for optional zener diode.
-9 position polarity voltage divider network
-Adjustable bias voltage for fixed bias mics
-Adjustable heater voltage regulated by CRCRCRC and LM317
-LM317 noise smoothed by CRC (for U47 type of bias)
I'm pleased to receive feedback and suggestions.
Happy diying!
Happy diying!
