SonsOfThunder
Nacho,
Here is my stab at your issue. I would only do the following to a single channel and then listen to it before proceeding. If you have access to a scope, it would be a good idea to use it to check for oscillations. I rather doubt that osc will occur using a 4558 but I'm just trying to cover all the bases here.
I would remove C9/13/15/32/35/37. I would then remove or replace the following with maybe 10pF to 22pF each: C10/16/33/38.
If you aren't concerned with the EQ performance, then the only OAs you really need to replace are M5 and M6. I could not find a thing on M1, the first OA (PC1010) is it a little potted OA or something?
The other mod that #might# help would be to add in parallel each of the series electrolytics with a 1uF film cap.
HTH!
HTH!
