StephenGiles
I can't get my brain around this so I'd be grateful for some help please. I built a few "What" compressors and because I had no VTL5C9s as prescribed in the circuit, I used NSL32s. I got these to work by decreasing the resistor into the LED from 1k to 33ohms. I've also messed about with the compression ratio since then, but that's una parva distinta de pescados.
Now, given that each type has a different light and dark resistance, does each type react by a different law according to the amount of current fed into the LED?
many thanks
Stephen
many thanks
Stephen
