UTC A-10 & A-24 Set for La2a Build
Lake Forest, California, USA
Hello all !
I've been a pretty quiet member here for several years. But decided now, finally after I have retired to build, at long last, a La2a clone.
So I've been searching for parts and was wondering about the UTC A-10 and the UTC A-24 transformers that this company is selling on eBay, link below. Can someone tell me, are these indeed the transformers originally used in the original La2a ?
https://www.ebay.com/itm/387401872739
Thanks much!
Greg
It will be hard to find them cheaper and sold as a pair "right now". A-24 are routinely $300 and the A-10 is often $400. If you need them "now", then i think the price can be justified.
I agree with CJ. They will only go up in price. Most UTC transformers have over doubled in price in the last 5 or 6 years.
Theoretically, transformers should just couple the audio magnetically, and introduce little or no coloration. The fact that sometimes they do introduce coloration generally is a result of less than optimum loading. The manner in which a device is employed is often as important as the device itself. Having said that, I would volunteer that you can buy vastly superior transformers from the Reichenbach tradition: i.e. Cine-Mag, Jensen, Bauer, even Edcor ... whose characteristics are orders of magnitude better than the old classic ones, and you can get them for a third of the price of the old UTC's and Triads. The use of high nickel cores and intimate winding techniques have improved performance by orders of magnitude. The LA-2A was a killer product because of the circuit designs, not because of its transformers.
You generally don’t get the original design inductance in a modern transformer. That may or may not be important, depends on the source Z, here the source Z can drive a modern output without loss of low frequency. Other circuits, it’s a problem. Only Hammond seem to still make transformers (800/850 series) that perform to spec under matching conditions, with winding resistances that resemble vintage transformers, and they sound much more like them. I’d argue they are superior with regards to those metrics.
