OK, hack time on the P-12.
I started to saw the can in half and the lid popped off. It is made not of metal, but of black phenolic, an old school insulating material. Polycrystilene wax inside. Goody goody, no black tar to deal with:
Time to break out the heat gun and de-wax this thing:
Drip drip, ooozzz ooozzzz...
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_c.jpg
Darn can got so hot that it warped. The x-former is exposed:
Piece of cake getting the x-former out as the brittle phenolic can breaks like a dry twig in a stiff desert wind:
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_e.jpg
Blue spaghetti insulation over the .015 buss wire break out leads:
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_f.jpg
Melting the rest of the wax now that the can has been peeled away.
Weird bobbin with horns, the horns provide a strain relief for the bus wire so the magnet wire does not get stressed to breakage. Could not find that bobbin in the Cosmo Corp catalog:
Please number your leads before you snip them. Otherwise your disection will be a waste:
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/P12_H.jpg
Snipped the leads and removed the x-former. Going to melt off a little more crud.
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/P12_i.jpg
Heating the rest of the wax off also makes lam removal a breeze. 18 EE lams. Count em if you don't believe me. Ooops, some short E's missed the pic. I am betting on 80% Ni, since the smaller size core means less room for copper. Maybe not. I will have to do some Al tests to be sure.
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_j.jpg
Your typical UTC glass tape wrapper. Heating the tape will insure that you do not rip any leads out as you un wrap the mummy within:
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_k.jpg
Looks like they wanted some space in between turns for leakage purposes. This coil was obviously hand wound with sporadic numbers of turns per layer.
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_l.jpg
This lam is turning up all over the place:
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_lams.jpg
Getting down to the pri/sec boundry. Notice the spacing between turns. One turn of glass tape was the insulation between the primary and secondary. No shield used on this x-former. The turns ratio is only about 1:1.58, and this is a low impedance x-former, which might explain the lack of shield. Remember, transistors sit on the sec. side, not a high impedance tube grid.
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_m.jpg
Closer look at the bobbin. Lead numbers get transfered from the wrapper to the bobbin once the x-former has been de-lammed. Otherwise, you peel off the lead numbers with the tape wrapper.
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_n.jpg
Ready to unwind the primary.
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_o.jpg
All done.
http://vacuumbrain.com/The_Lab/TA/UTC/P-12/p12_p.jpg
What's that you say? You want the vitals?
Well,
