The EF806s is pretty much the same than an EF86, audiophile products wasn't the reason when Telefunken introduced the 800 series of tubes, 800/802s, 804s, 805s, 806s as an long life version *10k hours min* of the EF80, EF804, EF85 and EF86. Those tubes were made for broadcast, military and medical machines like EEG/EKG. The EF804/806s uses all the same mechanical parts like the EF86 only that the mica wafer were heat treaded and different cathode nickel was used. Soundwise EF86/804 and the 'S' are the same, were for the 'S' version a better noise figure is practical build in. The heat treaded mechanical parts allow a higher grid leak resistor due to virtually no sneak currents inside the tube. You can replace the EF86 for a EF806s without any problem. However, even Telefunken tubes are called the bench mark for electron tubes, the Valvo made E80F is the best version out of the EF86 family type of tubes. Telefunken as well as Valvo developed their versions out of the rimlock type EF40, that was the post war version of the EF12. Valvo did a better job with microphonics, S/N and random noise. Compared to the EF806s made by Telefunken, the Valvo E80F also features heat treaded mechanical parts plus a gold plated first grid that allows a higher grid resistor than the Telefunken tubes, this difference comes handy with grid leaks above 3G ohm and High SPL. Without the gold plated grids tubes with 3G ohm resistor and high input levels tents to change its start up current point easier.
One reason why Neumann original used the Valvo EF86 instead of the Telefunken EF86 was not only price, Valvo cost 1/3 less than Telefunken, it was that Valvo tubes worked better in tube mic circuits. A standard Valvo EF86 was about DM1.95 in 1962, just a bit under the technical performance of a Telefunken made EF806s that went for DM16.00 in 1962. The E80F was DM25.00.
The E80F was mostly used as an electrometer tube and circuit were high grid leaks were needed, like O-scopes, etc. not used in consumer electronics like the EF86. It is still easy to find and works great in all applications that ask for a EF86/806s?. One minor problem is the taller size than EF86, but it fits without any big problems in U67s?. E80F made by Valvo were sold here in the US under the Amperex brand as 6084.
Best regards,
Oliver
