I'm looking into alternative ways of reducing gain for compressors other than the usual CV on the IPT.
You are not the first.
The 6AS6 tube for example, was designed for suppressor grid 3 modulation whilst keeping, current constant. I would have thought that would eliminate thump.
Reduce, not eliminate. This IS what someone did given the rise of tape recorders and access to a tube-bending factory. Plenty good enough for $99 home recorders. Not quite good enough for Pro use. Maybe fun as an "effect limiter", especially in high-level pop music.
There is also a trick (AH!
Heikki has it) of using two 6J7 cross-coupled. Variation of G3 diverts current to plate or screen. The cross-couple gives fairly constant DC current but variable signal current. If you want large GR, you have to keep output level low, which probably reduces S/N. This was done with BJTs in many TV Audio chips, as a Volume control for fixed input max-to-zero output, which suits it well.
I've fooled with many limiters, not comprehensively. With the right tubes and heavy idle current (more=better), the classic push-pull limiter can be too-good for FM/Phono tho not quite to CD standards. Before photo-resistors became illegal, a good photo-R job could equal it. FETs come a little short but will all the frills are really good enough unless you use all 16 bits (most tunes don't). dBx/THAT VCAs leave them all in the dust: low hiss, low THD, no thump.
IMHO, most "good" limiting should start with a slow average gain-ride. This may be a place for motorized pots.
