https://soundandmusic.ch/wp-content/uploads/2021/11/MasteringEQ_open800x436.png
..looks like the variable capacitor is for the light-blue to dark-blue unspecified control for the shelving high band, slightly grandiosely named "Aircap". Probably controls shelving frequency, i.e. the cap in series with the viper in bax circuit.?
Nice! Thank you! I hadn't seen any internal pics, and think you nailed it here.
I've actually got one of the 1951 (and a 1954) on order now being built, and your observation has me even more keen to explore this device. Will hopefully be just a few more weeks until it arrives.
I've heard some pretty tricky things about its pairing with other devices in line, and the output impedance of 500 ohms will take some consideration.
Along these lines, I believe you might be the perfect person to give me a leg up on where to start with this follow-up question...
I have your passive Gyraf G21 (hands down my most favorite and intriguing piece of gear so far).
Would it be futile for me to attempt to put your G21 directly after the 1951, given that the 1951 has a 510 ohm output and according to the manual the G21 has a 500 ohm input?
Or is this okay because It seems to mimic the older style of matching impedance (600:600)?
I'm hoping to use the G21 as a final shaper and clipper after this EQ, but I'm not sure if I need an intermediate solid state active device between them.
I realize I'm probably just going to have to try it, but I was curious if you had any insights into this pairing.
Apologies if this question veers too far from the intent of this thread, I can message you instead if that's more appropriate.
