[quote author="RogerFoote"] I set this up for peak mode. That uses the EC+ port and EC- is gnd'ed. Followed dn101 for that, but had to find the diagram for using the EC+ port in the data sheet for the 4301, pg7/ fig13.
I will look at pad 5 also. One thought was to just remove the cap and make a small switch pcb like on the GSSL or G1176 connected where the cap was and mount the timing caps on the switch pcb. Thoughts?
I thought the pic was small too, but I clicked on it and it loaded a bigger one, did you try that?[/quote]
Ah..., I've never used the E+ port before, good to know that. Though you could just as easily drive OA2's inverting input with a resistor and use the E- port.
As far as pin 5, I guess there's no point switching out the cap in peak mode ( as it states its small to disable the logging filter; swapping the peak timing cap would be a better idea (or maybe resistor R4?). Pin 5 is a traditional tie point for the stereo mode, though then you would have to be able to trim the detector input plus or minus 3db...
The pic opens a little small for me to see some details, but it works...
