As abbey road said, you should use 100K linear as in first schem, the second one is adding a cap and a op amp, so more THD there... if you don't have it you can have some DC offset, depending on the op amp could vary, I'd put something like 8k2 resistor from non inverting to ground bypassed with some film cap, value is not critical, just for decreasing noise, something between 1µ and .1µ should work ok. If you want 10dB boost you could decrease pot and inverting input resistor value as you want, also non inverting resistor to something between max Z and min Z seen by non inverting...
Max is when pot is at min or max, just feedback in parallel with non inverting input, min is with pot at mid point, so 1/4 pot value in series with non inverting input and all this parallel with feedback
So something between ((Ri//Rf)+((Rpot/4+Ri)//Rf))/2 would be a nice value, for min offset in all the gains, if you want min offset when muted or max just use Ri//Rf and if you want min offset with some gain you'll call 0dB calculate Z to this position.
In my mixer I use active gain in summing and a inverting amp to deal with inverting in summing amp, in the summing I use a servo DC feedback, the inverting amp is fixed gain, so I just put the non in input and feedback in parallel values and use as said before and have very little offset... Now I'm thinking in using transformer summing for my busses to create the master so the transformers will do the inverting task and this amps will be out.
JS
