Voltage reference trim
Freq Band
GDIY Supporter
Electra City
Even though I am using two 10-turn pots, I am not getting the fine resolution I desire with the trim network shown here.
I would like the "fine" trim to be able to have a 1mV range over the pot's entire span.
(which I believe will give me 100uV trim per turn, on a 10-turn pot.)
Any suggestions?
=FB=
I'm going to ignore your R1 because it is a fine trim on the nominal "5.000V".
You start with 5V and you want 100uV/turn??? 5V/100uV= a 50,000-turn pot.
One 10-turn won't do it.
Two 10-turns can fake a 10*10= 100-turn pot.
I think you need five 10-turn pots.
Or a re-examination of what you really need: a micrometer or a surveyor's chain.
You want some variation on this.
But basically your R2 is 5V-0V, so 0.5V/turn. Do you really need 5V-0V here?
Given 0.1% (1/100th turn) resolution in R2, the minimum jump is 5mV.
The pot I added will multiply by 1.00 to 0.9901. At 5V in that is 5.00V-4.95V, a 50mV span, 5mV/turn.
Change 1,000K (1meg) to 10Meg, you get 5mV span, 0.5mV/turn, 5 microvolt nominal setability.
> I put a 1meg resistor between
I was going to say.... that direct-connect is NOT how the sheet shows it; and you may well have burned or drifted the precision internal divider with careless pot-turning.
> How does this change the circuit ?
A smart geek like you should learn to solve any Voltage-Divider problem on a cocktail napkin.
Your statement of problem is incomplete without saying what range you want XX resolution over.
You're right, I should do the divider calc.....but not tonight, I'll make an error ('zzzzzzzz)
The 1meg to wiper....I was trying to steal the idea in this model......
Yes, I want the full range of trim, 0-5V. (Circuit here above is idea for "fine" portion only).
=FB=
