MagnetoSound said:It's a fairly common compromise. As was mentioned earlier in this thread, the designer of this amp was pushing the tubes past the limit of their design rating - not such a problem in the glory days of Mullard (although even then redplating was not unheard of), but much more difficult in these days of cheap Eastern manufacture.
If you can find the sonic compromise (you will lose some harmonic richness and sustain but hopefully avoid crossover distortion), I imagine your wallet will thank you for it.
firehazard said:Hi,
sorry to have missed your question.
If your amp has a standby switch then the information I gave you might be bad.
My amp is from 1964 or so.
I have no experience of the modern version.
So while your bias voltage seems good you have a few things to think about.
47ma seems a little close to the 50ma I seem to remember as max for an EL84. You should be able to run a lot colder before crossover distortion is an issue.
Warm tone should not be a problem here. No negative feedback. Designed for Rock and Roll.
Take care
