peter purpose
[quote author="JPrisus"]just to clarify, VR4 is the trimpot, and U1 could be half of a TL072?[/quote]
VR4 is indeed a trimpot and U1 on mine was a 5534 single op amp. Overkill, but that's what I had to hand. There is additional circuitry to glue on (compensation caps and such). Just look at the specs of the op amp you're going to use.
As PRR mentioned, op amps are so cheap that running two signals into one dual op amp is a false economy and requires additional gizmos.
As NYD says, this circuit is really only good for a gain of more than one.
I was under the impression that you were running unbalanced, as was I.
ayethengyaw
pooter
ayethengyaw
pooter
