Sleeper
I've got some vu meters (of a sort, not true vu) that I'd like to use.
trolled the posts and tested them with a 10k resistor and 1.5v battery.
The needles move up w pos voltage and down with the battery turned around, so I'm pretty sure I need a bridge rectifier.
Three questions.
does the rectifer go before the 3.3k resistor?
And I hook up the rectifier as follows yes?
source + and - to ~ and ~ on the rectifier
and rectifier + to meter+ rectifier- to meter-
Just about any bridge rectifier should do right?
It is only getting a couple of volts tops... I have a bunch of 300piv rectifiers here.
Kelly
Three questions.
Kelly
