Larrchild
If I'm given the choice of a coil of wire wrapped around some iron or electrons passing through holes of silicon, I think I know the answer already. =)Any passive element under current and/or voltage is the source of noises. The question is, what is better noise source, what is worse.
Edit;.. assuming that you are not using the ccs as an electronic ripple filter and are feeding well filtered/reg'd B+ to both.
