thomasdf
Hi all
I recently got myself a Wem custom Copicat (tube version) very cheap because it was broken... or supposed to be broken.
I ended up putting a missing tube (6BR8) in it, and fixing a few soldering points that looked tired.
It is now working fine except that I have a whole lot more wet signal than dry signal so it's pretty hard to use it with a guitar and an amp for instance.
Do you guys know what could be the problem here?
My final goal is to turn the Swell pot into a dry/wet pot, do you know if it is possible? Being a sound engineer as most of you I would like to have this feature so I can use it as a parallel FX (100% wet) while mixing in studio.
Thanks a lot in advance
Thomas
Thomas
