paulcheeba
- Joined
- Mar 29, 2017
- Messages
- 205
I’d like to buy some 150v
1-2uf caps. No lower than 150v please. Thanks.
That must be why I can’t find them. Thanks David.That cap would never "see" more than 60V DC normally.
>> I have just purchased over 50 aluminum electrolytic capacitors that have a -- 450V -- rating with no issues or problems in finding a source. So, I cannot imagine why you -- are/would be -- having trouble finding a 150V capacitor!!!That must be why I can’t find them. Thanks David.
He want's wet tantalum capacitors. Different than Electrolytics.>> I have just purchased over 50 aluminum electrolytic capacitors that have a -- 450V -- rating with no issues or problems in finding a source. So, I cannot imagine why you -- are/would be -- having trouble finding a 150V capacitor!!!
https://www.mouser.com/c/passive-components/capacitors/aluminum-electrolytic-capacitors/aluminum-electrolytic-capacitors-radial-leaded/?capacitance=1 uF|~2 uF&termination style=Axial~~PC Pin|~Radial|~Through Hole&voltage rating dc=150 VDC|~200 VDC|~250 VDC&instock=y&sort=pricing&rp=passive-components/capacitors/aluminum-electrolytic-capacitors|~Termination Style|~Capacitance|~Voltage Rating DC
I would be cautious with this statement. When you have a passive power supply the voltage there can be quite high before the tube starts to conduct...That cap would never "see" more than 60V DC normally.
If you want to use the mic without tube you are rightHe want's wet tantalum capacitors. Different than Electrolytics.
Because I don’t need a regular electrolytic I have thousands. Thanks for your wonderful wisdom.>> I have just purchased over 50 aluminum electrolytic capacitors that have a -- 450V -- rating with no issues or problems in finding a source. So, I cannot imagine why you -- are/would be -- having trouble finding a 150V capacitor!!!
>> Your comment here comes across to me as being "sarcastic and snarky"!!! As I am only trying to help you out, I can only hope that I am wrong about this.Thanks for your wonderful wisdom.
