[quote author="rafafredd"]Please, give me a reasonable explanation for the above.
PLEASE, PLEASE, or I´ll go crazy... I can´t belive it. The same info pass throught the same DA and them throught the same amps and it sounds diferent?[/quote]
I would say it was either not the same info passing though the DAC, or not at the correct speed.
Remember if the CD's are hard to read, you won't hear whats on the CD, but what the error correction thinks should have been there.
And also remember that CD players for some reason actually work mostly like record players. They do not read the data sector by sector as a CD-ROM drive does. They just read the data at approx. the correct speed and feed whatever data they read to the DAC. This is also the reason that unstable mechanics can cause jitter, and the reason that mechanicaly stable CD-player can sound better than unstable ones. The stability of the clock also matters, as it's used to control the motor etc.
What I don't understand is why the data isn't just fead into a large FIFO and then played back accurately using a stable clock... That way the mechanical parts wouldn't matter.
Best regards,
Mikkel C. Simonsen
