What do you thinka about the painting tube? Another stupid idea :D
ln76d
Gallifrey
Since last time am hyperactive i have many different weird thoughts!
What do you think about painting submini tube with the black heat resistant paint!
Yes that's right - like AC701 - but this is not about the look!
I don't remember where, but i found some info about submini tubes and their photosensitive nature.
Maybe a little bit o paint wouldn't hurt?
Wasn't something like that, part of the reason the VF14 had that metal outer casing?
I suppose you use a transparent body for the microphone?
(Otherwise it is already pretty dark inside the microphone, so photosensitivity won't be an issue!)
Good one ;)
Unfortunately if the pipe isn't painted inside or it isn't dark mat brass - bulbs like EF732/5840 emit pretty strong light from the heaters. These *******s glowing pretty strong what's reflected inside  microphone body.
I didn't take my question from theory  - i noticed that using submini tubes ;)
I also think that way but from the other side i have proper paint and a tube for test :D
Much more i consider problematic of tube painting - due to heat for instance.
I wonder if the thin layer of paint can short life span or affect any other tube parameter.
Who knows what was originally used in tubes like AC701...
granger.frederic said:
the ac701 black painting contains metallic particles for electromagnetic insolation
Great info!
Still possible to make :)
micaddict said:
Mr. Faraday again?
Correct me if i'm wrong but mr Farady  idea is to connect it somewhere?!?
I know it's cage :)
Typical farady cage is grounded at least at the surface.
Cables with so-called farady cage are also connected to ground at least at one point.
Or i'm wrong here and my  examples aren't true faraday cage?
Groove Tubes for a while covered their microphone selected tubes with black heatshrink. A marketing gimmick I'm sure.
Maybe not so bad idea?!?
Dear Tim if you are already here - did you get my PM about two capsules?
After posting about the heatshrink I realized it could dampen microphonic behavior.
Yes I got your PM. Since they'd be non-standard I'm still thinking about it.
