What should I do with my UTC A-22?
babyhead
Loas Angeles
DIYers-
I have had the good fortune to come across a UTC A-22 for cheap and wanted an opinion as to what I might build around it.
Pri Z= 500 with CT
Sec Z= 125 + 125
Maybe a GPultec or the output of the FFOC... or the input of a Bloo?
Thanks-
BH
I have some of those also. It seems that it´s a very intriguing transformer. I´m sure there will be a nice use for this one.
NYDAVE posted a schematic that used it a while ago. It was a dynair lineamp or something like this. This is not in fact what I think would be the best use for my A22, but maybe we could borrow the output stage for a micpreamp. Interestingly I thought that this wasn´t meant as a PP output transformer, as it´s a gapped core, and thus you don´t need DC cancelation etc.... And I don´t think it´s windings are perfectly symetrical, but Dynair used it in a PP circuit, feeding the output transfistors throught the primary of the transformer.
Also, it says 20mA, so I don´t think it would work well as a NEVE BA283 output transformer, but it should be worth trying. How much current do we have throught the windings of the trafo in a BA283 amp?
Now, what would be really interesting to try would be putting it inside a cathode follower, WCF or SRPP circuits that can drive 600Z, but with no coupling caps before it. It would be "inside" the circuit. I have thought about it but I´m not sure how would one implement it. :?
Interesting...
So a G9 or a Pultec output without the bypass cap? What about a solid-state signal from something like an API, Hardy 990 or JLM style opamp? What are the pitfalls of using an (or this) input transformer on the output 1:1?
Thanks-
-BH
BH, the structure is all wrong for that. Notice that layer 5 should be grounded to the shield for maximum inductance:
:razz:
And you want my A-22????
Layer 5 is pretty deep in there... What kind of circuit do you find this transformer in?
This is like a puzzle to me. :?
What about it backwards?
-BH
I was just funnin. It's almost summertime, which means mental dis-orders.
Seriously, the A-22 might or might not work on the end of an API. Let me check the inductances. I will be right back.
It might work great, but I still think you can find other transformer for this purpose. The UTC A22 is a very high level iron, high quality iron with lots of headroom and an airgap. Not very easy to find iron like this one, specially today, so I still think a DI output transformer isn´t the best use for this one...
Still, if it sounds great and it actually pass audio often, nothing wrong with this... Better than sit in the closet like mine. :?
I really don't have use for another DI... I have an Evil Twin :twisted:
However- I would like to use it for a TT project... I have waiting in the wings fabio 312s, 1176, Calrac, Pultec, & Forssell Optos... maybe for a discrete What.
I am leaning towards the comps next because today is the day that I lost I lost my 2254s and my GMLs. :sad: Not that they were ever really mine!
[quote author="rafafredd"]The UTC A22 is a very high level iron, high quality iron with lots of headroom and an airgap.[/quote]
Does anybody know for what purpose this was designed in the first place?
I mean, it can take 20mA of DC, and it's high level, but the DC isn't enough to build a SE output with all the bias current flowing thru the transformer *and* making ue of its full power capability at the same time. (Or is this wrong?)
JH. (also having two of these from ebay)
I guess it would stand more than 20mA OK. As I said, If I et crazy enought, I´ll probably try it in a 283 ne%$%$ve out stage,...
[quote author="jhaible"]
Does anybody know for what purpose this was designed in the first place?[/quote]
"Transistor interstage or output", according to UTC.
I'm going to end up with several of these if I decide to part out those Dynair line amps.
