[quote author="CJ"]A-22, A-23, A-36, A37 are the same primaries stuffed on an M6 core. Secondaries have different turns for different output impedances.
Less turns than an A-20 primary to handle the current with bigger wire and not saturate the core with DC.
Equivalent of the A-22 in non dc might be the A-21, which has less pri turns to make room for some shielding.
I would imagine those 36 ohm primaries for the 22, 23, 36, 37 would give you about 1 henry pri inductance as opposed to 10 henries for your run of the mill A-10, which NYD correctly predicted as having a reduced low end response. [/quote]
Thanks for the info. Is there anything about transformers you do _not_ know ??
So, does this mean the A-10 also uses the same core as the A-22 ?
And, does this mean that I can run 6mA of DC thru a A-10 ?
If the L is 10 times higher, I have SQRT(10) as much primary turns, so I could apply 20mA / SQRT(10) of DC. Does this make sense?
JH.
