[quote author="barclaycon"]This isn't the first time that SSL have had a crack at adding harmonics.
Remember their EQP option? In response to Power Station's request for a more 'Pultec' sounding EQ they did this version. It was identified on the desk channels as being the ones with orange caps on the Bass EQ knobs.[/quote]
That much is true... however, there was no harmonics or distortion generated, beyond what was done in all the other EQ's (82E02 was the only other option I recall at the time that the EQ-P was introduced... the 82E242 ["black-knob"] and '292 [original G-series] alternatives came later.)
If you look at the schematics, it's just a differently-shaped sidechain filter, which was also designed to interact in the same way that Pultecs did.
Being passive, the Pultec basically drops the signal level by around 20dB. The make up amplifier then has a corresponding 20dB of gain. You get a "boost" (of let's say 18dB) by reducing the attenuation at that frequency point. However, if you "overlap" two bands, you can't "gang them up" for 36dB (2x18dB) of boost... because the available boost "runs out" as it were...
So the interaction and the bandwidth/boost interaction (widening the bandwidth on a Pultec noticeably reduces the available peak boost) was designed to mimic the Pultec's behaviour, because -as you rightly pointed out- people went to the Power Station becasue of their mighty, mighty rack of Pultecs. SSL wanted to sell Power Station a console because they were trying to crack the American Market at the time. (Andy Wilde -later of Euphonix- was sent over by SSL to coordinate a sales 'push' in America in about 1984... right about that time... the rest is history!)
So the official SSL wording was along the lines that that the EQ-P was 'designed to emulate the curves and behavioural character' of the Pultec equaliser... The power of suggestion did the rest. There was no attempt at distortion or waveform reshaping other than by frequency-related amplitude gain. -Basically if you put a sinewave in, you got a sinewave out, with gain being the only variable.
I don't think for a minute that SSL intended to decieve people into thinking that it added distortion; that simply wasn't their way of doing things- but when people started to 'buzz' about the "pultec EQ option, the majority of the interest was in the unfounded supposition that it "warmed" the sound.
-I think I still have the schematics at home... It was never liked as an EQ. We tried it, we didn't like it. I don't think that anyone ever liked them in fact... -That is to say that I certainly never met anyone who said that they did!
Forgive the interjection: info included just for clarification... -See the rumour began all those years ago that SSL was 'harmonically imitating' the Pultec, and people spread around the misunderstanding that the EQ-P included 'tube distortion' simulation. Ever since then I've felt bound to correct the misapprehension. -Were it in fact true, I'd have cloned it as a separate effect by now... and I'm sure that people would have lobbied SSL to make it accessible without the EQ itself, so that they cold use it as a separate processing option... -I know I would, for sure!
Keith
