user 37518
n
craptical said:Pops usually indicates DC in audio path.
/Dave
user 37518 said:Well i did the replacement and i was really careful but ill check it out, im not perfect , thanks for all your replies guys, ill check the module with a magnifying glass, and ill let you know, in the meantime if anyone has another idea, please let me know
user 37518 said:Actually i didnt test the module before the recap, i just saw a lot of bloated and puffed capacitors so i decided to replace them all before anything, i think this was with the module before even changing the caps, ive changed a lot of caps in my console, entire modules, and almost in all of my gear, and never had a workmanship error on any of them, im very careful with my stuff although sometimes ill forget to cut some leads on new components but this is not the case, everything is double checked since that last time i forgot to cut the leads.
Im running out of ideas here, ill try to take all of the modules out of the console and leave only the master section in and see what happens, but i dont think thats it.....
Im back to where i started
