Arno said:wait, are you sure the vertical position on both channels is identical?
When you short both inputs to ground, you should only see a single flat line. (most scopes have an "input-grounded" next to the AC/DC setting, just for this)
If that's the case, then yes, you have a dc-offset problem![]()
Arno said:What output is driving the scope?
Arno said:Ac- or Dc-coupled?
Arno said:Try loading it with a reasonably sized resistor like 10K
