I've been working on this a bit more, here and there, and re-drew the schematic:
The sidechain is now fed from the 6V6 plates.
I split V3 cathode resistor from 2K to a pair of 3.9K, although I will probably change this to a pair into a shared resistor.
Negative feedback also added from the 6V6 plates to V3's cathodes. I measured about 60db gain before adding the negative feedback. Haven't measured again yet. The negative feedback made a big difference with lowering distortion and lowered hum a bit too.
I've made C6 and R17 variable, on rotary switches. Also trying a 25K pot for now between R17 and the CT of T4 as attack control
200uA meter strapped across a 470 resistor between C1/R5 and R6/R7 - I'm also using a 1K resistor across the meter terminals to zero
It is sounding good- fairly clean with modest limiting and gritty in a good way with heavier action
One thing I'm curious about, is there any advantage to T4? I'm not familiar with other tube compressors or limiters that use an interstage transformer in this position
I thought I might add a balance control for good measure, although thump hasn't been noticeable. Any suggestions on best placement? I thought maybe between R6 & R7 on V1/V2 plates
