Can you post exact schematics of what you do and expect to do?
Yes. I don't really understand their purpose, except maybe linearizing the impedance...? I made a simulation with and without them. Seems to me without is more correct.Looks to me C6 discharge path is P4 parallel to P3 + R18 || R19, ignoring the transformer resistance.
That looks amazing. Congrats. Do you have any recordings of it?I've finally had a couple of weekends to return to this project. In the meantime I came across another for sale and now I have a pair. The second unit has Thordarson input & interstage transformers and the same Stancor output transformer as the first.
The new unit is wired same as the print schematic with a minor addition- the T3 & T4 center taps are fed from a 10K resistor off the B+ line. I've wired my original unit to match this and I've been testing some modifications in the side chain. I made attack and release both variable and added a 'Speed' control inspired by the Sta-Level / Collins 356E / GE BA-9 circuits. I've been testing values for the capacitors and resistors by ear and how far I can push it until I get unstable behavior.
It's working well in this current configuration.
I also had a front panel made, mounted the units to rack shelves and used Molex connections to bring the circuit points I need out to the panel.
In measurements taken in Room EQ Wizard it seems to be fairly full frequency with a few db hump up around 12 or 15 kHz.
How's do the high and low-ends sound on this? Based on these, it's pretty linear between 50Hz and 5KHz, but there's that weird wobble from 20 to 50Hz and that spike around 15KHz. How do those sound on actual music?I tried removing R18/R19 in one of the units and frequency response/phase changed more pronounced with a hotter input signal/heavier limiting:
Unit 1 (R18/R19 left in place), -40dbfs frequency sweep
Unit 2 (R18/R19 removed), -40dbfs frequency sweep
Unit 1 (R18/R19 left in place), -20dbfs frequency sweep (heavier limiting)
Unit 2 (R18/R19 removed), -20dbfs frequency sweep (heavier limiting)
Thanks. Haven't had any time to work on this recently, but will try to share some recordings/further tests on next pass.That looks amazing. Congrats. Do you have any recordings of it?
My next move will probably be to wire the sidechain up as MaxDM suggests here.I think r16 should be connected to the center tap of the GR transformer and the cap to the diodes, in a normal fashion. Then the transformer with the extra tube is actually an improvement over other typical designs, which take the signal for GR unbuffered from the output, such as the 176 etc.
You could remove the sidechain transformer and use capacitor coupling instead. For example copy from here how to wire the sidechain.Well, ideally I would like a relatively flat response.
Thanks I've been looking at the UA 175 as well.You could remove the sidechain transformer and use capacitor coupling instead. For example copy from here how to wire the sidechain.
That means different things to different people. Did I miss a measurement? Many things pretty far from flat can fool the ear that doesn’t know. Many highly colored flat things seem not.Well, ideally I would like a relatively flat response.
Totally agree and hence "relatively"That means different things to different people. Did I miss a measurement? Many things pretty far from flat can fool the ear that doesn’t know. Many highly colored flat things seem not.
