Well, one could ask: what could be the cause of the noise in the amplifier?
The PNP transistor doesn't do any amplification, so it does not contribute much to the sound and/or noise.
The main suspect is the FET. Knowing the Chinese, they use
anything that they have available...
What is the type number of the FET? I would first substitute the FET and also check the values of the polarisation and gate resistors. (Usually 680 M.ohm or 1 G.ohm.)
By the way: did you do the test with a (68 pF or so) capacitor instead of the capsule?
If the noise level is still high, it is clear that the amplifier body is the problem.
(I am almost tempted to buy a 'Chinese' MK-012 and see how we can improve things!
