Thanks John, I'll have a closer look over the next day or two.
Yes, at the time I did check the 5532 output pins to see if it was indeed doing this, but only with a voltmeter. I have yet to to scope it to see if there are any other gremlins lurking on the O/P of those chips. From memory I think I scoped the preceeding sidechain opamp output pins, but they all appeared clean, so it must be that last stage just before the CV input to the VCA that's causing the trouble.
I do remember scoping the outputs of the audio stages, and there was definitely nothing untoward until I got to IC2b (the buffer hanging off the VCA output), where I started seeing stuff like in the above photos.
The intent of the design is that only the one higher opamp will dominate and other will be pegged to opposite supply.
