Ifudontlikebees
Member
Hello everyone! I recently wired up 8 balanced direct outs for a friend’s Yamaha M1532 using CAPI ea2623 like out transformers. I took the direct out signal from the 100 ohm resistor directly before the pan pot and jumpered it to the unused pin 4 of connector C3. That then goes to the input of the transformer and then to the direct out. The issue I’m having is on channel 4, the direct out works for a second and then goes away really quickly. When it goes away the buss routing stops working for channel 4 too. When I remove the jumper wire, the module works as it should and the buss routing works again. What could be happening? Am I missing something here? Thanks for all the help in advance, here’s a link to the schematic. Input module is on page 13 and 14.
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Yamaha-M-1532-Service-Manual.pdf
