I figured shielded cable wouldn't matter, especially with bare copper wire, but it was easy to run them and its tidy. Grounding to chassis didn't seem to work either. Do I have an impedance mismatch? I've noticed that when I've tried my Seventh Circle Audio A12's as makeup gain, there isn't enough gain and everything sounds thin. My N72's and Green Pre's work though. I'm sending subgroups out via my Lynx Aurora. Here are specs:
Input Impedance Balanced mode: 24k Ω
Unbalanced mode: 12k Ω
Output Impedance Balanced mode: 100 Ω
Unbalanced mode: 50 Ω
Output Drive 600 Ω impedance, 0.2 μF capacitance
For the Summing mixer I'm using 10k Resistors in series and 220ohm shunts. I took the shunts out at the time when the pictures were taken fyi. The shunts are used to create more separation between channels, correct? I'm trying to understand the math, according to http://electronicdave.myhosting.net/miscimages/mixnetwork.gif
It seems simple, but I don't understand how...
R(which is 10k)= (N-1)/(N+1)*Z
N=8 channels and Z should be around 1200ohms(the input Impedance of my SCA N72 Preamp)
My calculation is 933.3
Divide that by 2 since its balanced
and it should be 500ohm resistors.
How did we end up at 10kohms?
or 5kohms? as in http://www.forsselltech.com/downloads/schematics/8chsum_2.pdf
?? Sorry I should break out my yamaha book haha
and sorry for hijacking this thread Marc!
