Wanted Yunpen switched, fused IEC inlet
Norfolk - UK
The standard Yunpen IEC inlet I use which has a switch, fuse and EMC filter seems now to be obsolete. I need just one to complete a current project (the panel that holds it has already been made). unpen no longer make a compatible alternative.
Part number Yunpen YQA201 although the YQA601 will also do.
Those are kind of a standard sized thing, They come with hole on the top and bottom, or with holes on the sides with little wings. I have Schurters here that are those dimensions. Newark/Farnell lists most of the unfiltered ones in Connectors-Power Entry.
The ones with filters are hidden under passive components:
https://www.newark.com/c/passive-components/emc-rfi-suppression/filtered-iec-power-entry-modules
https://www.newark.com/schurter/3-104-206/power-entry-module-medical-8a/dp/52AC2580 This is a top and bottom hole unit on sale. This will at least get you the numbering scheme for these brands via the data sheets.
-Tony
Thanks Tony. Panic over! After some trolling of the internet I came to the same conclusion. Initially I could not find any filtered switched ones at Farnell - the way they now classify stuff is very confusing and their search engine is poor. It's a relief they are still a standard size made by lots of people.
