dandeurloo
wow, looks coo!
Volume11 said:I made two using dans case, with the eleven stepped option, and they both lined up perfectly. The extra steps make a big difference to my ears, so I'm glad I did it this way.
Che_Guitarra said:Volume11 said:I made two using dans case, with the eleven stepped option, and they both lined up perfectly. The extra steps make a big difference to my ears, so I'm glad I did it this way.
Does it require a different input pot to build up the 11-step version? I've already ordered the parts from the BOM spreadsheet provided by Bluzzi, so if I need a different item it'd be good to know - just so I can order ASAP.
electrisizer said:i had an issue with FF 2448mk2 unit too. it was a hum around 120hz (i think to remember...) whats your noise?
BTW i was not able to solve the problem with this PSU and took another one that runs perfect till then.
sharpeleven said:electrisizer said:i had an issue with FF 2448mk2 unit too. it was a hum around 120hz (i think to remember...) whats your noise?
which one did you end up using (PSU)?
Che_Guitarra said:Hmmm... do these cases need a direct ground? I'm not getting any continuity from the enclosure to the 0 volt power pin... not sure I need to though?
Che_Guitarra said:FF sent me two kits (one more than I ordered), so I've build both. On one of the kits a cap blew straight off the PSU PCB within 15 second of firing it up - the other one just can't muster a full +24V to the units.
digistu said:Che_Guitarra said:FF sent me two kits (one more than I ordered), so I've build both. On one of the kits a cap blew straight off the PSU PCB within 15 second of firing it up - the other one just can't muster a full +24V to the units.
I don't know whether this will be of any help for your second PSU, but I'm pretty sure the one pictured has one of the electrolytic caps in the wrong way round. I've built a couple of these, and as I remember all the caps face the same way - in your picture, the one two above the blown cap is the opposite way from the rest. Perhaps that was the problem with the blown cap too?
