Mazieresantoine
Active member
- Joined
- May 12, 2014
- Messages
- 41
ok so now the vumeter is working, I think i really have a electricity problem somewhere.
I will check tomorrow the sound.
tata said:"Product Code: SYMKIT
Availability: Coming soon"
please Gustav, how soon?
Rocinante said:tata said:"Product Code: SYMKIT
I was just gonna post the same thing.
Gustav said:You can check the PSU feed by disconnecting it and measuring the outputs from the PSU board - at least that would eliminate a possible problem.
Sometimes people short the wires on lacquered transformer wires, which means they will have hard time getting a connection. Thats usually the cause of fallouts.
Did you check the different trimmer values when placing them?
Gustav
Mazieresantoine said:Gustav said:You can check the PSU feed by disconnecting it and measuring the outputs from the PSU board - at least that would eliminate a possible problem.
Gustav
Ok so I check it today by changing the FET and the comp is working for 20mn, when i came back to calibrate it, i put power on and the same problem, no bass on the sound.
So maybe something happen?But impossible for me to know why...
I'm a little bit lost
Rocinante said:anyone know of a link to where the wiring scheme is?
jicama said:Hello, I finished a dual fet compressor and so far both sound great and works as a spected, still need to calibrate the meters, but I have a small issue with the noise on the right channel, not too much but compare it to the left is not the same, turning the input knob 3/4 to the right on the right channel noise appears on my analyzer -70dbs, I checked cables, connections, switched Ic's but the noise still there, any one have an Idea where to start looking?
Thanks for your help
What kind of noise are you hearing,hum and overtones?jicama said:Hello, I finished a dual fet compressor and so far both sound great and works as a spected, still need to calibrate the meters, but I have a small issue with the noise on the right channel, not too much but compare it to the left is not the same, turning the input knob 3/4 to the right on the right channel noise appears on my analyzer -70dbs, I checked cables, connections, switched Ic's but the noise still there, any one have an Idea where to start looking?
kante1603 said:What kind of noise are you hearing,hum and overtones?jicama said:Hello, I finished a dual fet compressor and so far both sound great and works as a spected, still need to calibrate the meters, but I have a small issue with the noise on the right channel, not too much but compare it to the left is not the same, turning the input knob 3/4 to the right on the right channel noise appears on my analyzer -70dbs, I checked cables, connections, switched Ic's but the noise still there, any one have an Idea where to start looking?
I think member zamproject is right,this is really an example how it should not be done!
Seriously,I even wonder that you only have "..... A small issue..."!
So here it goes:You should lift nearly all wiring and do it once more.
The transformer is mounted correct so far.
Try to run all your audio wires so they don't cross any parts in the psu,especially not the transformer.
Also twist(!!!) wire pairs like the ones going from and to the XLRs as well as the others!
Try to run them short to the front panel etc.,in general:Make them look nice and clean.
You will be amazed how good your compressor will work after you're done. :
Happy "cleaning",
best regards,
Udo.
Yep,and post a front pic too,we all want to see how it looks (I bet....).jicama said:Jejejej!!
Thanks for the advise!!
I'll post back when I clean this jungle!
zamproject said:Jicama
Can I also suggest as you have to redone the whole wiring to made some change in the layout.
rotate 90° both comp card and translate to the left, max as possible (view from front) hoping your case have enough depth.
rotate 90° your PSU card and translate to the right,
By this you easy resolve audio cable (from card to xlr connector) over PSU
also take care of the main switch cable I see black one (switch to trafo ?) like touching opamp and lundhal :-\
best
Zam
