Re: Racking Spectra Sonics 101
« Reply #140 on: March 12, 2011, 05:11:58 AM »
Quote from: JLM Audio
I am currently racking a pair of these using Triad A67j input transformers and Jensen JE-123A output transformers. This may seem like a silly question, but looking at the pinout in the picture, if I send the 0v  from the input transformer to pin E, and the 0v from the card ( pin F) to the power supply common, where is the best place for me to connect the 0v from the Jensen output transformer?
http://www.rocksuresoundz.com
Production Music and Sound Effects
« Reply #141 on: March 14, 2011, 01:59:01 AM »
Bump....Anyone out there?
« Last Edit: March 14, 2011, 02:01:31 AM by rocksure »
AJMAC
« Reply #142 on: March 25, 2011, 04:36:48 PM »
So I'm racking up a pair of 101 cards using Joe's diagram (Thanks Joe!)  I am using A67J input wired 600:600 and HS66 on output.  I have a couple questions however..I have the output of the card wired to the primaries of the transformer and the secondaries connected to XLR out.  It works, but after re-reading the thread for the 10th time it seems I've got it backwards.  Since the transformer is 1:1 does it make a difference?  Should I wire secondaries to the card and primaries to the XLR?  Also, PRR mentions using a resistor in series to keep the card from damping out the iron sound.  Could someone elaborate on this in noob terms?  Also, what value resistor would be suitable?  Thanks!!
« Reply #143 on: June 17, 2011, 12:00:36 AM »
Hello,
I first want to say what an amazing board this is. It is remarkable how polite and intelligent everyone is here. Thank you all so much for the information on the spectrosonics 101 cards,I am trying to breadboard one as I type. Cannikin, the 103 board you have is a summing card.
I think it might be the unsung hero of the Spectrosonic console. If I understand it is 0 ohm input summing amp. I think it predates the SSL low impeadence summing amp by 20 years. Is thee any way you could post color photos of the front and back of the card,I would love to try
to bread board one. Once again thank you all for your information, I look forward to participating in this great forum.
Drew Baker
« Reply #144 on: July 28, 2011, 03:27:37 AM »
I finally got my 2 channels of Spectra Sonics 110 racked and up and running. They sound really good. Nice and warm and fat. Quite a bit of work and time consuming to do, but well worth the effort and cost of racking them up. No issues with noise or hum, as I was pretty careful to ground everything as well as using metal shields round things like power supply and transformers (just to make sure).
I am not too clued up on electronics really, and so I had a few minor problems working it all out, but with a bit of help from a friend who is an electrical technician we nutted the issues out. I have Triad A67-J transformers on inputs and Jensen JE-123-A's on outputs. I used a JLM AC/DC to power them, and JLM go-between and variable pad kits for attenuation, phase and 48V. On the picture I have posted here, I have the labels for these underneath the switches, they should have been on top. I have subsequently changed the labels. I have no output gain control: output is fixed with the use of 42k resistors. I have around 40db of input gain control via the JLM input pots and attenuation switches.
I am very happy to have these.  :)
« Reply #145 on: January 30, 2012, 03:44:54 PM »
Hi all,
Just a quick note to say that this topic is fantastic,lots of useful info !
Some pretty neat racking here too : knowledge and ingeniosity go a long way.
I just wanted to add an insert to the circuit ( for connecting an eq or compressor)
What do you think would be the optimal spot ?
« Reply #146 on: March 18, 2012, 04:03:36 PM »
Hi Guys I am looking to trade a pair of SS 110a/502 modules in a really cool rack with PSU and VU meters for some modules for my console.
Here is a movie of the unit at work:
http://dl.dropbox.com/u/5629729/IMG_3001.MOV
Now for the deal! I am looking to acquire more Spectra Sonics modules, so if you have any spectra sonics parts or modules that you never racked up let's trade. I am trying to put a console together and need more 502/110a modules and possibly other parts. I am looking to trade this unit, loaded with two modules, for four of your raw modules etc.
So if you never racked yours up here is your chance to plug and play and help a console get rebuilt. This rack and vintage API meters with FiveFish PSU, custom rack etc plus mod/rewiring labor from a tech has easily cost me $1500.00 not counting modules. But it sounds amazing!
In addition to this amazing rack I have other console parts, bus modules, anodized gold meter panel, some old meters and more. Just trying to get my console running. And lemme tell you I am not one of those guys who famously lucked into one. I have paid through the nose for every part. Just a love affair with this sound.
pm for more info. It currently runs at 17.5 volts, but can go to 24 volts if you want to mod it. Also the attenuation pots you see are very high quality but not wired up as I liked the simple -10 -20 -30db switches. I also have it wired for line in but the XLR's are on pigtails - you can run them out a hole or install the TRS jacks I have included in this deal (pictured).
When I find out how to post pics I will. I have 100% positive trading on ebay since 1998 and Gearslutz since 2003 and can provide references and contact info if you PM me!
« Reply #147 on: March 18, 2012, 04:07:50 PM »
Here is a pic of my Spectra Sonics 110a/502 racked pair with original SS API VU meters.
« Reply #148 on: September 14, 2012, 08:33:47 AM »
It looks really nice. I'm still loving the sound of my racked pair. They really excell on electric guitar cabinet micing among othe rthings.
toddro
« Reply #149 on: March 18, 2013, 06:48:46 PM »
I know this is one year old, but I wanting to rack up a 110/502eq set and my eq's came from an old broadcast console with a custom faceplate.  Can anyone post a straight-on shot so I can see the toggle switch & gain / freq pot positions?  When I pulled them off the console I was forced to leave the faceplates behind and need to build a new one.  Somehow, the photos of the console I took have disappeared and I have been unable to locate a shot clear enough to see what the positions are.
Superjimmer, nice build!!!  That is what I am shooting for!
Thanks.
Todd
Whoops
« Reply #150 on: May 05, 2013, 02:02:14 PM »
duantro
« Reply #151 on: December 28, 2013, 12:43:57 PM »
Getting ready to rack a pair of ss101's and really appreciate all of the info here! Cheers
j.frad
« Reply #152 on: June 10, 2014, 09:02:11 AM »
Hi everyone, what would happen if I lowered the supply voltage to, say, 16v ?
Wondering if I can make 500 series modules with them...
bxt403
Re: Racking Spectra Sonics 101 New
« Reply #153 on: August 31, 2018, 11:28:38 PM »
I've realized that Spectra Sonics modules should definitely be sent to Ogden and Spectra Sonics (now apparently called Spectra 1964) for repair and/or refurbishing.  I sent two 101s that didn't match (age wise) and Spectra replaced one of them (while also refurbishing them).  They did an excellent job repairing my 110s, as well (and converting them to 110As).
In any case: I've just completed racking a pair of 101s so figured I should share some gain resistor values as an alternative to the (I think) "JLM" method of having 3 gain settings and a variable pot at the input transformer.
You'll need a non-shorting rotary switch as a shorting type causes loud thump sounds (from gain instability).  I  haven't had any issues with gain stability using a non-shorting type rotary switch with my 110 (in that I hear a very faint clicking sound).   I noticed the clicking sound is significantly louder with the 101 (likely since the 101 only needs a +24 VDC supply to work while the 110 requires + & - 24 VDC).  It's not as bad as the loud thumping I'd hear when using a shorting type switch with the 110 but it's still apparent.
Note that I did the algebra on the gain equation found in the original Spectra Sonics manual and made a spreadsheet to do the calculations.  The numbers given are for the EXACT (theoretical) resistor value that'll yield the EXACT gain value number.  Since the gain equation is given in the 101 manual: it should be easy to figure out which gain is yielded from the actual resistor values that are available from electronics suppliers.
The spec sheets for the 101 and 110 both state the gain for each module is adjustable to 40dB to 55dB (which contradicts the manual that gives a resistance for 35dB).  Given the specifications of the 101 (and 110): I'm certain 40dB is the optimal MINIMUM gain setting .
Gain (dB)     Resistance(kΩ)
    40                     11.111
    41                     12.638
    42                     14.402
    43                     16.449
    44                     18.834
    45                     21.629
    46                     24.926
    47                     28.845
    48                     33.545
    49                     39.244
    50                     46.248
    51                     54.994
    52                     66.143
    53                     80.728
    54                     100.476
    55                     128.489  (the "actual" value I got was 127kΩ @ 54.96dB)
Also: Jensen (at the time of this post) makes the line input JT-11SSP-6M and the line output JT-11SS-DLCF transformers (where I suspect the SS might actually stand for Spectra Sonics).  I'm guessing that the sound from these transformers will be less coloured than using vintage Triad A-67J  + HS-66 transformers (albeit only the DLCF mentions 50% Nickel content while the 6M sheet doesn't list anything about its Nickel content).  Pricewise: a used Triad A-67J and the Jensen JT-11SS-DLCF are probably the best combination (given how expensive the HS-66 tends to be and JT-11SSP-6M is).
« Last Edit: September 02, 2018, 08:00:06 PM by bxt403 »
Last post November 23, 2005, 01:19:54 AM
by raysolinski
Last post April 16, 2008, 09:52:38 PM
by 3nity
Last post May 15, 2017, 03:55:26 AM
by bxt403
Last post February 01, 2019, 12:59:54 PM
by L´Andratté
