Re: 3D "AIR" EQ - "Night EQ" PCB's Complete!
« Reply #920 on: June 02, 2013, 04:20:01 AM »
nobody has the PCB for PSU?? :-\
bm_dong
« Reply #921 on: June 10, 2013, 11:50:20 PM »
Does anybody have the self etch files for this?
It would be greatly appreciated!
EDIT: Nevermind! found em!
« Last Edit: June 11, 2013, 12:01:14 AM by bm_dong »
Rockitdog
« Reply #922 on: June 19, 2013, 04:16:58 AM »
Just incase anyone else is looking for them.
http://www.twin-x.com/groupdiy/thumbnails.php?album=485
Thanks to Peterc for these.
« Reply #923 on: July 05, 2013, 03:58:19 PM »
Hi friends,I have few questions about this Project. :)
1.about connecting rotary switch to PCB,what are the Q and b pins??and next to Q we have 2-6, what does it mean??and pin 1 shouldn't be connected to anywhere?
2.Under R26 we have a resistor,what does it mean by 0R link??put a jumper instead of this resistor??
3.why some people put jumper instead of CIN1 and CIN2 Caps??
4.why we have 4 pins for LED??both of them are connected to the same source!!!
Thank you everyone. :) ;)
« Last Edit: July 05, 2013, 05:50:48 PM by positrons »
pachi2007
« Reply #924 on: July 07, 2013, 11:25:54 AM »
May seem "Q" but it´s "A"
pachi2007
« Reply #925 on: July 07, 2013, 11:49:11 AM »
I think this is correct but please verify
Harpo
« Reply #926 on: July 07, 2013, 12:11:02 PM »
the shorting links between 2a,3a,4a,5a and 6a are missing in the pic, else only the 'off' and 2.5kHz settings would work. Just have a look at the schematic (schematic and previous posts should explain positrons remaining questions as well).
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
peterc
« Reply #927 on: July 07, 2013, 03:23:08 PM »
As harpo says, do the shorts, but I think that is indicated in the pic?
0R link is the same as a jumper.
Input caps can be replaced for DC coupling.
The 2 pairs of pins are in parallel, so only 2 connections.
Peter
If opportunity doesn't knock, build a door.
pachi2007
« Reply #928 on: July 07, 2013, 03:41:57 PM »
Thx Harpo and Peter.
I took a look and I think I got it now. I hope :-)
« Last Edit: July 07, 2013, 05:37:52 PM by pachi2007 »
pachi2007
« Reply #929 on: July 07, 2013, 03:43:53 PM »
From schem
« Reply #930 on: July 07, 2013, 04:20:16 PM »
Thank you to all of you.I understood all of them. ;D
« Last Edit: July 08, 2013, 05:00:03 AM by positrons »
« Reply #931 on: July 14, 2013, 06:00:34 PM »
Hi again, :D
 I bought two types of rotary switch 2*6 and there is a difference between them.one of them is like this
1.
and the other is like this:
2.
both of them are 2*6 but when I turn number 1,it seems that it has 12 positions because it says TIK 11 times,but number 2 has 6 positions and it says TIK 5 times!!!
which one is correct??we want 6 positions according to the original version of EQ,isn't it??why number 2 says TIK 11 times whereas it has 2 pins in the middle and 12 pins around them??
« Last Edit: July 15, 2013, 07:08:55 AM by positrons »
Harpo
« Reply #932 on: July 14, 2013, 07:07:08 PM »
for pic1 turn the switch full CCW, remove the fixing nut, remove the washer and displace the end-stop washer to pos.6. done.
« Reply #933 on: July 15, 2013, 09:00:17 AM »
Thank you Harpo ;D.I didn't pay attention to that washer.Shame on me :P
Whoops
« Reply #934 on: July 16, 2013, 08:20:08 PM »
The PSU PCB is the same used in the green pre.
You can also use the PSU PCB from Gustav used in the SSL 9K project
« Reply #935 on: July 19, 2013, 08:12:22 AM »
Thank you for your help.
you mean This PSU??
http://www.lorcan.me/wordpress/wp-content/uploads/2011/09/layout.png
I don't understand output of this supply.why it has for pins??and what are the names??+ - and Ground??
another question,GREEN Mic pre is the clone version of focusrite GREEN???is it a good pre??you think it is worth to make it?? :)
Harpo
« Reply #936 on: July 19, 2013, 10:02:24 AM »
I don't understand output of this supply.why it has for pins?? and what are the names??+ - and Ground??
The four pins from left to right are 0V reference voltage and +15V, -15V, +48V in respect to this 0V reference voltage.
For the 3D-EQ you don't need the +48V phantom voltage rail, so you'd leave out all parts above the AC-input connector and left side of the 1000uF/35V caps, just keep the 4 rectifying diodes between AC-input connector and bottom 1000uF/35V cap.
Just look up the green-pre in the meta or read the green-pre help thread. ;)
« Reply #937 on: July 19, 2013, 04:36:37 PM »
Thank you so much Harpo for your excellent explanation. :)
I will read the topics, I only wanted to know that what is this micpre and see one pic from the original factory made version.
« Last Edit: July 20, 2013, 05:30:53 AM by positrons »
Harpo
« Reply #938 on: July 20, 2013, 08:43:07 AM »
Pic from an ancient A*** console? Nuthin to do with Ficusrote. No cloning of units that are still in production or still on sale here.
It is a mic preamp. IMHO the room, mic placement and performance in front of the mic are 99% of perceived differences between preamps. YMMV.
« Reply #939 on: July 20, 2013, 11:38:30 AM »
yes pic from an ancient A*** console :) yes you are right the room, mic placement and performance in front of the mic are 99% of perceived differences between preamps.
Last post December 18, 2019, 11:49:49 AM
by manulaudic
Last post August 25, 2009, 07:06:28 PM
by nhaudio
Last post October 23, 2009, 07:53:29 AM
by ytsestef
Last post December 13, 2010, 05:36:54 PM
by pucho812
