Bringing this thread back in summer of 2024! Just read thru no joke the entire thread and learned so much. Huge thanks to khs, Peter, harpo, and everyone else for all work and sharing of knowledge here.
Not entirely sure what happened but it seems the DIYRacked version of this has some bad blood behind it? Wish I’d read thru this prior as I’m currently working on building this from diy racked. The design and build of this diy buildout seems far more efficient.
Regardless, as the diy noob I am, I’m currently running into issues. All my pcb’s are stuffed and plugged in. Unit powers in fine and passes audio just fine in bypass. When eg is engaged, L channel goes MIA. R channel seems to be working more or less (getting noise introduced into the signal as I boost above 7-8 on the faceplate.
However, my main issue that I’d love input on is in the PSU. Running at +- 18V using a toroid, 317/337 regs, and 2 5k trimmers to calibrate for the +-18v. Problem I’m having is I can’t figure out how to get the correct voltage at the dc output terminals that feed the pcb’s.
Can someone please tell me where to measure from. With my VM red probe on the +/- output terminals, I get vastly different readings based on where the black probe is. Black probe on dc ground terminal, I’m reading -.5v on the positive side and -39v on the negative. Black probe on the main AC ground (screw holding the torpid in place) I’m sitting perfectly at +-18v. Thinking I may have the toroid primaries and secondaries wired into the pcb incorrectly.
