Potato Cakes
Re: D-AOC PCBs - the building and help Thread
« Reply #1480 on: June 21, 2019, 06:50:24 AM »
thx!
anyone else has experimented differents leds or resistors?
Volker did a full write up on this with measure data/fancy graph. It's in this thread. It should answer your question thoroughly.
Paul
OneRoomStudios
« Reply #1481 on: July 06, 2019, 06:02:02 PM »
Finally got this one done with some machining/wiring help from a friend.
petermontg
« Reply #1482 on: September 28, 2019, 10:14:41 AM »
Hi guys I have an old DAOC here that has a 120hz area problem
When idle it sits -90db but raising the volume raises the noise.
Problem is apparent in both channels.
I've changed the torodial and many grounding schemes.i am missing some voltage around the tube mostly 40odd at the 82 nearest to I/o
Tbh am starting to scratch my head here any input would be appreciated.
petermontg
« Reply #1483 on: October 01, 2019, 05:47:44 AM »
Problem solved replaced B+ regulator and grounded the casing of the alpha pots.
Happy days!!!
[silent:arts]
« Reply #1484 on: October 01, 2019, 06:08:28 AM »
Thanks for reporting back  8)
AD797
« Reply #1485 on: October 03, 2019, 10:18:51 AM »
I am having serious trouble  with the last steps of my d-aoc. So far its running, voltags are looking good. Unit passes audio, input works like expected. The problem appears with the 500k pots/switches. I got some pre soldered switches from ebay and to be honest i don´t get them. Can someone please guide me how to connect the switch propper?
Thank you!
https://abload.de/image.php?img=img_20191003_1535241tkle.jpg
https://abload.de/image.php?img=img_20191003_153405rdk70.jpg
https://abload.de/image.php?img=img_20191003_153532wjkbf.jpg
AD797
« Reply #1486 on: October 03, 2019, 10:39:06 AM »
omg, forgett about this... sometimes...
AD797
« Reply #1487 on: October 03, 2019, 11:05:47 AM »
Ok, all pots in place and working. right now i use a ll1521 at the input and output is transistorless.  Seem i build a filter too :)
Strong high boost and lack of bass. Any ideas?
weiss
« Reply #1488 on: October 03, 2019, 11:48:02 AM »
I had the same problem once with my lundahls. Did you wire the transformers correctly?
AD797
« Reply #1489 on: October 03, 2019, 11:58:47 AM »
problem apaears also when i am without transformer at all... :)
weiss
« Reply #1490 on: October 03, 2019, 01:18:01 PM »
Ah okay. Hobbyist had the same problem back then. Seems like it occurred because of bad grounding.. did you check that?
AD797
« Reply #1491 on: October 03, 2019, 02:17:31 PM »
ha, youre right, my unbalanced cabling was just not correct. unit is now unbalanced and workes propper and sounds huuuughe!
just my meters are crazy... needle is dancing but at the other side like in a gssl. strange...
AD797
« Reply #1492 on: October 03, 2019, 02:49:14 PM »
fixed. last thing...  there is some high frequent whir very down at around -120. guess i have to exchange my just twisted cables with shielded ones...
weiss
« Reply #1493 on: October 03, 2019, 03:31:34 PM »
glad it worked out!
yeah maybe. did you rack it?
AD797
« Reply #1494 on: October 03, 2019, 05:05:14 PM »
its already in a case...
AD797
« Reply #1495 on: October 04, 2019, 11:11:42 AM »
Someone test the LL1531 Input Transformer here?
Potato Cakes
« Reply #1496 on: November 02, 2019, 08:08:34 PM »
Hello, Everyone,
After a couple of years of this sitting around, I am now nearing completion of gathering all of the parts needed and finally worked out resistors values to use in stepped switches for the 100k and 500k log pots. The last thing I haven't yet to decide is the output transformer. I thought about the high nickel CAPI versions, but the primaries at 75ohm and BOM lists one that is 10k:600R. Is there a way to add some sort of resistor array from the PCB to the transformer to balance the impedances or is this a characteristic inherent to the transformer that can't be externally manipulated?
Paul
[silent:arts]
« Reply #1497 on: November 03, 2019, 02:48:40 AM »
10K : 600R impedance ratio ≈ 4 : 1 turns ratio.
The 2503 transformer can be wired in 3 : 1.
Potato Cakes
« Reply #1498 on: November 03, 2019, 11:08:54 AM »
I guess what throws me off is thinking of the transformer windings with resistance values instead of winding ratios. I'll give ones from Jeff a go.
Paul
Potato Cakes
« Reply #1499 on: November 04, 2019, 12:03:33 AM »
Is there a guide for the wiring the CW/Wiper/CCW for the 100k and 500k pots? Did I overlook it in this thread?
Paul
Last post November 28, 2008, 04:25:43 AM
by [silent:arts]
Last post August 10, 2011, 10:10:47 PM
by JimiH
Last post December 10, 2009, 05:43:37 PM
by Junction
Last post August 13, 2018, 10:11:57 PM
by TDM
