Mic Loading Confusion
I would try if I had some ribbon mic... May be to try to build one from computer winchester magnets and kitchen foil to experiment? :green:
Awful thick, heavier than air.
Peel the foil from cigarette packs.
There's a knack to peeling. Some brands are easier than others. If you just can't, try soaking the paper off.
Note that there are some stunningly low-price ribbons now. As you say, modern magnets make it easier. Bending iron and winding transformers is low-wage stuff.
[quote author="PRR"]> kitchen foil to experiment?
Note that there are some stunningly low-price ribbons now. As you say, modern magnets make it easier. Bending iron and winding transformers is low-wage stuff.[/quote]
Do you mean something like this one?
Or this one?
clintrubber said:
[quote author="Wavebourn"]
Hey, hadn't seen that second one yet.
That one has a double ribbon arrangement; the two ribbons are side by side. I've seen it used in another inexpensive ribbon mic with a single ribbon transformer so the output impedance was pretty high (just below 1k). Can be nice in front of a guitar amp, but the other China ribbons are more universally useful.
[quote author="Rossi"]That one has a double ribbon arrangement; the two ribbons are side by side. I've seen it used in another inexpensive ribbon mic with a single ribbon transformer so the output impedance was pretty high (just below 1k). Can be nice in front of a guitar amp, but the other China ribbons are more universally useful.[/quote]
Thanks Rossi for the info :thumb: Hadn't seen Apex-'incarnations' before.
Peter
May be good also as a center mic for stereo recording in nice reverberating environments.
