>> Classic ribbons were designed to work into a high-impedance input: a transformer with the secondary connected to the tube's grid, and no terminating resistor. Use them into a 1.5k load, typical of modern mixers, and you overdamp them, leaving you with muffled highs.
> I am wondering why would be that and what is the theory behind it?
Compare with all other common mikes. A ribbon has a smaller diaphragm area and a weaker magnetic circuit. It does not catch much power, it does not transduce efficiently. Of necessity, it is designed to a target efficiency higher than any other common type, so that despite its losses it can give a usable output.
The diaphragm is "small" all across most of the audio band, but starts to get not-small at the top of the band where diaphragm and baffle size approaches a fraction of a wavelength. Now we have some acoustic loading. This appears in series with the electrical output, somewhat like a hi-compression horn driver reflects acoustic loading as a higher midband input impedance. If the ribbon's electrical load is infinite, that added resistance has no effect. If the ribbon is loaded, the top droops off.
> The reason Beyers work fine with low loads is that they are tiny (about 0.06"x0.910") and work as very rigid pistons--only God knows what is the tuning frequency
I bet they are corrugated at both ends, the rigid part limply suspended, just as cone loudspeakers are. And the bidirectional types "must" be tuned to the bottom of the audio band. The acoustic response rises with frequency, the mechanical response must fall with frequency, so it must be mass controlled over the useful range.
They will not see "real" acoustic loading until half-wavelength approaches 0.233" or 11KHz. The effect may be negligible for another octave or more due to the non-square dimensions (the acoustic impedance gets Real slowly). So the rise of electrical impedance above half-wavelength may have little effect.
> absolutely essential to meticulously compensate for the associated gain loss.
Oh baloney. Decide which product you want to "win". Perhaps the one you like best. Perhaps the one with the best dealer mark-up. Make sure it is louder than the others.
