tardishead
I have heard from a reliable source who was instrumental in dub reggae at the time that certain reggae engineers used to take mono signals and divide them into treble and bass using crossovers or low pass/high pass filters - and then feed them into different amps/preamps - meaning they could take treble sections and drive them hard through tube gear to achieve a certain degree of gnarliness but process the bass at not such high gains to maintain clarity and punchiness - and then they would mix them back together after processing.
Can anyone see any underlying problems to this. Would there be phase problems from inserting 2 entirely different preamps for example one tube one transisor????
Kind of like multiband processing. I have often wondered about this. Like with a drum sound that sounds awesome when the treble/hi mid has a lot of 2nd harmonic distortion but the low end sounds awful. If you could process them differently and then combine them that would have interesting results I believe.
